Nest
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Dec 2 2017 9:26 PM
Hello
Today my nest thermostat was installed and connected up.
It now appears in my homecontrol overlay
Should I be able to turn it up and down via home control or just view the current temp.
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beojeff
USA
Posts 2,012
beojeff replied on Sun, Dec 3 2017 11:38 AM
I've been using Nest for years and love it. After a short while of it learning your patterns, you really won't need to make many adjustments. I have it in my "Goodnight" scene to turn down the heat for sleeping. I don't have a beovision with a home control overlay, but I know you can control it using the BeoLink2 app. I usually control my Nest by voice using the Echo.
To fill in the missing part of environmental control, I recently integrated control of the Dyson humidifiers using Global Caché. The Global Caché was very easy to set up once Global Caché tech support told me that you must use a METAL paperclip to reset the unit. I had thought it was defective when I was trying to reset it with a plastic paperclip.
Page 1 of 1 (2 items) | RSS
