Beo 4 Cinema partially broken - service manual needed
This post has 4 Replies | 0 Followers
mariuszf1
Spain
Posts 12
mariuszf1 Posted: Tue, Feb 10 2015 7:28 PM
Hi Beoworld Forum!
After a long long time of searching i found a Beo4 Cinema with light function and i just can say its so fantastic to finally have the possibility to see the content of the display without switching on any room lights, especially when you have to use the soft buttons. I always had to count the numbers of pressing list to get to my desired function... Now its over :) But the problem i have is that the upper part of the keyboard (all buttons above the coloured ones from the TEXT row to TV row) are dark. That means the fiber optic cable inside must be broken at some stage. As i am familiar with that kind of stuff i had the idea to open the remote and fix the problem. The easiest way: calling b&o dealer and asking for service manual. Unfortunatelly not in this case... He told me there is nothing more in the system for that type beo4 (1162604). Now i really hope someone of you had a chance to save it and could provide it. The dealer just sent me the newest service manual, which i suggest will be totally different as the remote has a completelly different interiour. By the way i was thinking the Beoremote would solve my light problem in a way but unfortunatelly its not working with anykind of stb, or apple tv or ps3. So that was a disapointment as well, even if it is a brilliant design piece. I will never stop loving my good old BEO4  :)))
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Feb 11 2015 8:46 PM
There is a section in the system for the Beo4 cinema in the archive section. Under service though, all that is available is:
We do not have any Beo4 Cinema in stock nor do we have any spare parts. We recommend selling a Beo5 if the customer's Beo4 Cinema fails.
Smile
Peter
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Thu, Feb 12 2015 9:11 AM
I have the same issue marluszf1, very frustrating!!!!!
Jonnie
mariuszf1
Spain
Posts 12
mariuszf1 replied on Sun, Feb 15 2015 2:39 PM
Thanks for the answer Peter! B&O Technician from Madrid told me something similar. However i was hoping to get at least a service manual to try to fix it by myself. At the moment i'm a bit scared what happens if i open it and can't get it back together Sad
Thanks for your reply Jonnie! That means there is a general problem with the fiber-optic in the beo4 cinema... I am like waiting for the day when i don't care if i break it opening the remote and then maybe replacing the fiber-optic cable with LEDs Geeked but in fact that would be something for Ulf from Germany to do, he has done so many great electronic parts for B&O in the past...
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Mon, Feb 16 2015 12:16 PM
Let me know if you find a solution?
Jonnie
Page 1 of 1 (5 items) | RSS
