Hi guys, i am buying a non-B&O TV and wanna to connect it with my transmitter and essence.
I have beolab 18 and 19 so i can connect them to the transmitter wirelessly. I also connect my essence to the transmitter using a RJ45 cable. The system works well when i connect it to my laptop. And now i want to use the system with a TV.
Here is the question, i notice that i can't control the volume using tv remote control if i connect it via optical with transmitter. Can i use the remote to control volume if i connect the transmitter to the tv via analog?
Also, since i have essence, i can use Apple TV and airplay with essence to watch a movie or listen to music. Can i control volume when i using airplay?
I know B&O has RCV3000 IR receiver now, but i don't know how much that is and i'm not willing to spend extra money if i can control volume with the device i have so far.
I'm wondering i can control volume if i connect transmitter to tv with analog output on the back of TV. Or i can control volume via airplay.
Thanks for the help!
I appreciate if some1 can answer. THx
Thank you for your reply!
How much is the BeoRemote and can i use it to control volume when connect my transmitter to a samsung TV?
Any idea how much the RCV 3000 is?
So far i'm getting a 3rd party TV since BO TV are just too expensive for me.
My transmitter, essence and lab18 19 works well when i connect to my laptop via a RCA-mini jack cable.
But it get a bit confusing when i try to connect a TV.
