HDMI Switch
doun
Posts 25
Hello,
I tried to convert these IR codes (attached to this post) received from the switch manufacturer in XML file but without success.
I have used the Beo5 ThirParty Configurator to generate the XML file but every time when I tried it with the BEO5, it didn't work.
Any idea?
Didier
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
I have converted your HEX Codes and produce an XML file for you.
As well as putting the number on the screen they are also assigned to numbers 1-4 and the Standby button also triggers Power
Regards Keith....
doun
Posts 25
doun replied on Wed, Feb 18 2015 4:26 PM
I will try it.
Best regards,
Didier
Page 1 of 1 (3 items) | RSS
