Hi ,
I'm a proud owner of a BEOPLAY A8 MK2.
It's connected to wifi, so far so good.
I use my android smartphone with DLNA to play radio and my local music.
Everything still good :-)
The BEOPLAY A8 does not go into a stanby mode, the green power led stays green.
I have waited for more then 8 hours , but still green
now i just push the button for 3 seconds to power the unit down , but then also the wifi connection powers down... i can not activate the BEOPLAY with my Smartphone, because its not visible on my network anymore.
So, now a have to turn the unit on or off by hand.....
is this correct , or does the standby function not work ?
Best wishes,
Marc
It goes into 'standby' - and is ready for your wishes 😀
Your A8 is working correct!
When you manually put it into 'deep standby', you will have to wake it manually too.
Most devices will go from green (power on) to orange (standby)
The led staying green is not logical in my opinion.
The unit stays warm , in standby i would expect the unit to cool down, using less power.
Pushing powerbutton for 3 seconds , all leds go off
Pushing powerbutton for 6 seconds , led turns red
Can somebody confirm ?
snikhaas:Most devices will go from green (power on) to orange (standby) The led staying green is not logical in my opinion. The unit stays warm , in standby i would expect the unit to cool down, using less power. Pushing powerbutton for 3 seconds , all leds go off Pushing powerbutton for 6 seconds , led turns red Can somebody confirm ?
snikhaas:Hi , I'm a proud owner of a BEOPLAY A8 MK2. It's connected to wifi, so far so good. I use my android smartphone with DLNA to play radio and my local music. Everything still good :-) The BEOPLAY A8 does not go into a stanby mode, the green power led stays green. I have waited for more then 8 hours , but still green now i just push the button for 3 seconds to power the unit down , but then also the wifi connection powers down... i can not activate the BEOPLAY with my Smartphone, because its not visible on my network anymore. So, now a have to turn the unit on or off by hand..... is this correct , or does the standby function not work ? Best wishes, Marc
Thanks Räuber,
Does the white wifi led stay on with your Mk1 ?
If i push the powerbutton for 3 seconds, the green led goes off an after a minute or so also the white wifi led goes off.
Can you confirm ?
snikhaas:Thanks Räuber, Does the white wifi led stay on with your Mk1 ? If i push the powerbutton for 3 seconds, the green led goes off an after a minute or so also the white wifi led goes off. Can you confirm ?
My software is the latest version.
Vielen Dank für ihre schnelle antwort :-)
