Best bluetooth receiver for use with B&O
This post has 12 Replies | 3 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Wed, Feb 25 2015 1:37 PM
With the H8 and Beolit 15, I am getting more into bluetooth than AirPlay, and I am looking to implement a bluetooth receiver to my system.
What are the different options for doing this? What are you using?
Simonbeo
Posts 1,451
Simonbeo replied on Wed, Feb 25 2015 6:35 PM
This question has been asked before , once by me and also this thread
http://archivedforum2.beoworld.org/forums/p/3550/32050.aspx#32050
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
leosgonewild
Helsinki, Finland
Posts 2,373
OK. But not really any good answers about it?
Aussie Michael
Melbourne, AU
Posts 3,730
leosgonewild:
Not sure what happened with my previous post.
I wouldnt recommend the iwave bluetooth receiver - its rubbish. I never got it to work with my BS8.
ethuijs
Posts 68
ethuijs replied on Fri, Feb 27 2015 8:53 PM
Don't you need a transmitter for the H8? To put in the 3.5 headphone output of TV or Beomaster?
Here are some:http://www.amazon.com/s/ref=nb_sb_ss_i_0_17?url=search-alias%3Delectronics&field-keywords=bluetooth+aptx+transmitter&sprefix=bluetooth+aptx+tr%2Celectronics%2C417
This one does both. Transmit for the H8 or recieve for use with Beolit 12.
Avantree Saturn Wireless Bluetooth Audio Receiver and Bluetooth Transmitter 2 in 1 adapter, with aptX for Music and T
http://www.amazon.com/Avantree-Wireless-Bluetooth-Receiver-Transmitter/dp/B0085HOM4K/ref=sr_1_6?s=electronics&ie=UTF8&qid=1425068648&sr=1-6&keywords=bluetooth+aptx+transmitter
Regards Edwin
kona
Posts 8
kona replied on Fri, Feb 27 2015 9:05 PM
I can highly recommend the Sony bm10.  This support aptx and the sound is really great. I have it connected to beosound 2300 with beolab 4000 speakers
http://www.sonymobile.com/se/products/accessories/bluetooth-music-receiver-bm10/
TWG
Posts 1,672
TWG replied on Fri, Feb 27 2015 9:14 PM
I'm using the Nokia MD-310 in white:
http://www.amazon.de/gp/product/B005PN0QRY?psc=1&redirect=true&ref_=oh_aui_search_detailpage
Easy to use, APT-X codec support and it looks nice!
ethuijs
Posts 68
ethuijs replied on Sat, Feb 28 2015 7:24 AM
Hi Leo,
Does the H8 com with a transmitter to connect to you Beosystem?
Al the other bluetooth deviced mentioned here are receivers. For sending music from your smartphone to the Beosystem. Is that what you are looking for?
The Avantree Saturn Wireless Bluetooth Audio Receiver and Bluetooth Transmitter does both.
I don't have one so I don't know what the quality is.
see also https://www.youtube.com/watch?v=l1VVQrT7da8
leosgonewild
Helsinki, Finland
Posts 2,373
No it doesn't. In my opinion, one should use the H8 with a phone for wireless. If you want to listen from your home stereo; use the wire that the H8 is delivered with.
What I am looking for is a Bluetooth receiver with a decent DAC.
When I have been using Airport express, I was able to use the optical output into an external DAC of my choice.
Millemissen
Flensborg, Denmark
Posts 14,680
Do you mean something like the Arcam rBlink?
leosgonewild
Helsinki, Finland
Posts 2,373
Yes. That is what I am looking for. What kind if experiences do people have with these kind of units? Is there much difference in sound quality?
Millemissen
Flensborg, Denmark
Posts 14,680
Not much!
I ditched bluetooth long ago....as AirPlay came into my world Smile
Surely bluetooth for music streaming has improved over he years, but I would never use it for my home listening. After all it is rather (file)compressed....even if the AptX guys try to tell us another story.
For small speakers like the BeoLit 15/A2 it is perfect, because you need no (working!) wireless network for it, and it can be used on the go. And the Android users have no orher choice!
Whether the Arcam-thing is better than other (cheaper) devices, is hard to know - you can make sound pretty impressive with the filters of the modern DAC's.
I guess you will have to try the Arcam rBlink (or similar) out at home to see if it fits your needs and expectations.
leosgonewild
Helsinki, Finland
Posts 2,373
Hmm.. Tough choice. I am using the Aune xdac2 with airplay. But most of the times when I start airplay, I have to turn it off and on in order for it to "sync" the optical signal. They call this a feature. Maybe I will just stick to Airplay through my apple tv. I didn't know that Bluetooth was more compressed than other signals..
Page 1 of 1 (13 items) | RSS
