Beovision 4 Setting up hd..... this display does support hdcp
harrykym
Posts 9
harrykym Posted: Mon, Feb 23 2015 5:32 PM
Hi I have a beovision 4 type 9324 which I am told is HD, I bought a hdmi to dvi Lead and connected it to my if sky box and the message "this display does support hdcp"
anyone got any tips for setting HD up?
mr_anders_son
sweden
Posts 1,710
Try this:
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
harrykym
Posts 9
harrykym replied on Tue, Feb 24 2015 7:31 PM
I don't have that option in the 00 menu
lano
Posts 161
lano replied on Wed, Feb 25 2015 9:04 PM
Is the Sky Box connected to the monitor or to the Beosystem?
BeoMegaMan
Posts 601
Sounds as if you are going directly to the screen. In which case you will need to find a Beosystem processor. The Panel itself doesn't handle the HDCP process, the processor does.
Ah, you know... A little B&O here, a little there
harrykym
Posts 9
harrykym replied on Sat, Feb 28 2015 1:40 PM
Monitor
Page 1 of 1 (6 items) | RSS
