Beosystem 3 and small panel
mjmedlo
Posts 922
mjmedlo Posted: Sun, Mar 1 2015 3:30 PM
All
I want to put a small panel in a kitchen.
I will connect to a system3 (probably) so I can be incorporated with the remaining system.
Anyone using a 3rd party panel with system 3 that is working correctly?
I anticipate use of the 1+2 to turn on the television but I only need a 26 inch panel.
Thanks in advance.
georgey007
Posts 74
http://archivedforum2.beoworld.org/forums/t/12554.aspx
Page 1 of 1 (2 items) | RSS
