I have an ST2164 cabinet -- You know the 4 shelf cube, with aluminum flip down doors with the plastic spring hinge mechanisms, which snap into slots on the doors.
The bits at the ends of the arms from the hinge mechanisms are notoriously fragile, they snap off at the connector, and lo and behold one of mine has snapped.
I've already inquired and found out that B&O no longer make these parts. Way back when I had ordered a replacement for when another one snapped, but that was years ago.
Now that B&O don't make these parts, I was curious if anyone in the know:
1. Has a spare, or knows where I can get one? (either the bit at the end or the entire hinge mechanism)
2. How feasible would it be to 3-D print the plastic bit at the end, and how strong are 3-D printed parts?
