Is there a simple way of removing the Beocenter 1 from the table stand ? We have acquired a second hand one on a black table stand to complement our older avant TV and wish to relocate it by car and would prefer to remove the TV from the stand. Any suggestions would be welcome. thanks .
At the rear of the set you will see a small hole where the set sits on the table stand. Inside is an allen screw. Loosen this screw and the set will lift off the stand.
Opman
I should have said that the set needs to be positioned in the centre of its turning circle to access the allen screw.
opman
