Parts to fit Beocenter 7002, Its the two plastic parts that are covered in grease Part no 2040 and 2021 (with 8.5mm hole)
I actually have the 2021 with the hole but the small piece at the end has broken off.
These parts were used on Beocenter 7000, 7002 and possibly others in the range.
Has anyone the parts to sell ?
John.
I realise the original parts will be cracked and damaged, With some experimenting I have found a way to repair and use the damaged bits. I need 2 of each part. So any one got damaged lift pieces to sell?
