Beomaster 6000 quad Perspex top wanted
This post has 5 Replies | 0 Followers
Jason
Redditch Worcestershire
Posts 177
Jason Posted: Fri, Feb 27 2015 10:08 AM
As the title suggests I'm after a replacement Perspex cover for my soon to be overhauled bm6000 quad.
not fussed if it has light scratches that I could polish up better, the one I have has a piece missing that I'm sure will always show if I try to piece
fingers crossed
Jason
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Fri, Feb 27 2015 12:05 PM
I would also like one for all of the above reasons ! Seems like its a recurring issue with the 6000, guess they didn't use glass for weight reasons.
Jason
Posts 177
Jason replied on Fri, Feb 27 2015 12:14 PM
I've never known B&o shy away from weight !!
Ben_S
UK
Posts 631
Ben_S replied on Fri, Feb 27 2015 2:43 PM
Hi Jason,
Would it be possible to get one made? I think the chances of you finding one are slim. And the chances of finding one in a good way even slimmer!
Ben
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Feb 27 2015 3:00 PM
Ben_S:
Hi Jason,
Ben
I would aim for a refabrication too I think.  It shouldn't be too difficult.  Finding someone to do it is probably the hardest part.
Dave.
Jason
Posts 177
Jason replied on Fri, Feb 27 2015 4:18 PM
Hi, thanks for your replys
yes I think getting the Perspex made would be the best option, if I did I'd try for glass but it's the multiple printing processes underneath that would be the challenge which is why I thought I'd see the likely hood of obtaining an original intact that I could polish up.
if I do go down that route I guess it will be a little cheaper to get a few done if there is a call for them, has anyone ever looked into it?
Page 1 of 1 (6 items) | RSS
