Hallo,
I switched my BeoSound 3000 for a Moment in my ML Installation. I have a BeoSystem 3 as Video Master and two BeoLink 2000. Because the BeoSound Moment has NL I had to use the NL/ML Converter. This setup seems to work. When I switch on Radio (the first stream from Tunein) from the BeoLink 2000 the speakers in the main room also starts to play. I tried to figure out how to setup this behaviour in the converter but found no settings for this. Any ideas?
Frank
You think you must set the NL/ML converter as AV master, Not just A master, then it will work. But then you must use the beo4 to adjust the volume. It won't work on the jukebox for now
Thank you Normann. You are right I chose A.Master. I will try and change the setting to AV.Master this evening.
Then it will work
You are right. It is like you explained here and in the other thread. I decided to use it as A.Master because you cannot control the Moment really convenient if you choose AV.Master (volume control as you described). I lowered the start volume in the main room. Hopefully the update in May is working as expected.
Thank you for you help. Frank
