Using B&O 5500 system B&O 1600 speakers
Professor David A Flynn JP
Belfast, Northern Ireland
Posts 116
Professor David A Flynn JP Posted: Fri, Mar 20 2015 9:24 PM
Can someone advise me if using the 1600 passive speakers is good enough for the for 5500 system?  I was thinking of upgrading to active speakers.  Any advice would be welcomed.  Thanks DF
Professor David A Flynn JP LM
Big Smile
Ben_S
UK
Posts 631
Ben_S replied on Fri, Mar 20 2015 9:39 PM
Slightly odd combo to be honest. Beovox 1600 were designed with systems from the 1970s in mind. They are a good speaker though!
Also, your 5500 system does not have power link sockets so you will need an adaptor if you wanted to use active speakers with the 5500. The 6500/7000 do have power link however.
Ben
leosgonewild
Helsinki, Finland
Posts 2,373
The BM5500 have line-out also, so you don't necessarily need a adapter. I am using my BM5500 with BL4000 without problems. (They don't turn off automatically, tho)
Page 1 of 1 (3 items) | RSS
