Please .. someone can tell me which SD card can I use to BeoSound4 , which format the card FAT or FAT 32 ..max. size of mem.card ?
Hi
Pending of SW version of the BS 4, up to 16 MB SD card, FAT 32
Ok tnx ...
tnx
thank you ...
kumjankovic:Please .. someone can tell me which SD card can I use to BeoSound4 , which format the card FAT or FAT 32 ..max. size of mem.card ?
BeoNut since '75
Back in 2010 when I had a Beosound 4 I had a 4GB SD card I was using. Fat 32. Beosound 2 however, doesn't accept anything greater than 2GB.
