Option Settings- Beosystem 3 (Main), Beosystem 7000 (Link), Beocenter 6 (Link, not MLed)
This post has 1 Reply | 0 Followers
kallasr
Germany
Posts 2,562
kallasr Posted: Tue, Mar 24 2015 11:57 AM
Dear Forum,
what is the right way to program option settings for my set-up?
We want to listen to radio, CD and A.TAPE in the main room.
We want to listen to radio, CD and A.TAPE in the Link room.
Access to DTV, VMEM etc. in the link room (from main room TV) is not needed.
Beocenter 6 is not on the Masterlink!
We want the BC6 to work as TV only (DTV/V.MEM), radio part has been turned off in the menu.
What Option Settings. (V.OPT/A.OPT/L.OPT) Need to be programmed for each System?
Thanks for your support!
Ralf
PS: No powerlink-connection between Beosystem 7000 and Beolink converter - as I read somewhere in the archived forum...
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Mar 24 2015 2:48 PM
I`d set the main room (BS3) to V.OPT 2, link room (BS7000) to A.OPT 1, and if you want to ml your video linkroom, set your BC6 to V.OPT 5.
Stefan
Page 1 of 1 (2 items) | RSS
