Does anyone have more info on how e.g an A9 can be integrated with the new Multiroom functionality, soon to be launched?
Will it take the place of e.g a Beolab 3500?
I´m told that the A9 will respond to a "join" command, and play whatever is playing over the NL/ML.
Wonder if anyone have more details?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Not much out there!
But since the A9 (new generation) has no ir-sensor, 'Join' will be pretty much the only thing, you can do directly.
And turning your complete system off (as with a long push of the red dot button).
When we know more, about how the updated BeoMusic app will work, we maybe will know, if we can activate 'Pattern Play' etc through it for playback.
Would be nice, if we - this way - also can activate other sources, which are on the NL via the NL/ML Converter.
I guess we need to be patient untill mid-May.
