BeoPlay S8 Connection Hub Settings
roryg50
Posts 2
roryg50 Posted: Wed, Jul 6 2016 4:34 PM
I currently have a Samsung 65inch plasma plugged into via optical connection to a S8 connection hub. This is then plugged into a Beosound 2 subwoofer. The sub woofer then has two Beosound 3 plugged into it. Does anyone know the best settings on the Sub for this set up?
I get a feint high pitched sound when the system is at low volume. My Sky box, apple tv and playstation are all plugged into the television, therefore the system plays whatever is on the screen. Does anyone know the best way of fixing the sound?
I've had a good look online, but can't find much advise about the connection hub and how to get the best of it. I bought it from my local B&O supplier and they did not know much either.
Any advise would be really appreciated.
Page 1 of 1 (1 items) | RSS
