Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Connect the BS3000 or BC2 and the BL3500 to ML. Connect the ML to your BLC NL-ML. Setup of BLC: VMaster
Program the sources/IR codes in the BLC.
Than you should be able to hear the sound of the BS3000 in every room (at least it works for me; in our living room we can listen to a BS3000, a BS5 or BS Moment; note I have additional BLC installed).
