Beomaster 5500 - disable and re-enable remote control
dave_n_s
Posts 54
dave_n_s Posted: Sun, Apr 19 2015 4:53 PM
I have seen references to a way of disabling remote control of a Beomaster 5500 and someone has posted a way of reversing this with a Beolink 1000.
How can  remote control be disabled?
Can it be reversed (for instance if done accidentally) via an MCP 5500
thank you
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Apr 19 2015 6:35 PM
Option 0 (remote disabled) Sound 0 Store
Option 1 (remote enabled) Sound 1 Store
Yes, it can be re-enabled if disabled. The unit still listens to remote signals in Option 0, it
just doesn't react unless it's an option command.
dave_n_s
Posts 54
dave_n_s replied on Sun, Apr 19 2015 6:56 PM
Thank you.
That works with a Beolink 1000 (STBY red dot = Option key)
I'm coming to the conclusion that this cannot be done from a Master Control Panel 5500.
Is that correct.
leosgonewild
Helsinki, Finland
Posts 2,373
What? Isn't it impossible to put the BM5500 in option 0?!?
dave_n_s
Posts 54
dave_n_s replied on Sun, Apr 19 2015 7:36 PM
I've just been through the "disable" sequence with my Beolink 1000 V4 on my 5500 and it doesn't have any effect.
That unfortunately stops me proving that the "enable" sequence works with this hardware or similar.
Reason for asking is I'm trying to help someone sort out a problem long distance - not stuff I've sold though!
PathElectronics
Posts 8
I can confirm that Option 0 does not work with the BM5500. I believe the Option 0 feature was introduced with the BM6500, it's generally used to disable IR when using it with an AV7000. It's been a while since I've done this, but I believe you could clip connection P16-4 on the microprocessor module to disable IR reception.
Nathan
Die_Bogener
Posts 192
Correct. The BM5500 does not have the Option 0.
While programming, the BM Shows the valid Option number in the Display. Invalid Options are ignored.
It has Option 1, 2 and 6... more i have not tested.
It is dependend on it's Software Version, but even the latest Version has no Option 0
Page 1 of 1 (7 items) | RSS
