My setup :
beosystem 4 with beosound 5 and beosound 8002 wireless module
here is the question: everything works fine until last night I unplug one beosound 5 speaker, it has no sound coming out after I plug power back. Then I unplug another beosound 5 speaker, it happened samething. So now, I only have rear beosound 8002 wireless sound, but no front both beosound 5s.
i tried to look for setting on beosystem 4 but I can't find any will help. Please help if you know how to fix this.
Ps: I did not touch any connection as same as before.
Many thanks
Hi and welcome to Beoworld.
BeoSound 5 - do you mean the BeoLab 5?
if yes, for how long did you disconnect them?
They probably are pin-protected.
