Hi, I acquired this system from my neighbour recently. I know nothing about it, but have all the manuals. I plugged it in, and after several attenpts at pushing buttons on the remote, and console, got a CD to play. Since then I cannot repeat the exercise! The CD spins twice when pressing 'cd', but then stops. I have no idea if it has suddenly failed, or I am doing something wrong. Any advice would be useful, as it seems to be a lovely bit of kit. (yes I have switched it off and on again). Radio works ok.
The neighbour was very elderly and I doubt it has had much use in the last few years,, it seems that it was made nearly 20 years ago, so maybe its had it (anyone fix these things??)
Simon
whoops
whoops treble post
