I have a "US" version that has a very simplified AC section without voltage selection and a AC fuse where the voltage selector is located in some models - no fuses on the #8 Board
Can't find a schematic with this power circuit design.
I turn on the main On/Off Switch and nothing happens - no Standby LED and no relay actuation
The transformer winding for the 15 volts reads good
Not sure where to check on this version to find out why there is no Standby LED -
The fuse to the 15 volt rectifier bridge is good
Thanks for any ideas in advance
Michael
