As always I am after a bit of advice....we have just extended our kitchen and at one end is our wall mounted BS2300 with matching speakers and I would like some additional speakers at the other end (its a very long kitchen!) which would run from the BS2300. Any ideas on the best way to go about this? And any recommendations?
Can you run cables?
Do you wan't the additional speakers to turn on with those from the 2300 ('daisy-chained')?
Or would you prefer, that they can be controlled independently from the 2300 speakers?
'PowerLik-daisy' through PL-splitter.
MasterLink through Converter via Aux.
Hi, I would like to run them wirelessly if possible and be synced to the beosound. I already utilise the aux with a Bluetooth audio receiver which I stream music to from my phone laptop. Any ideas?
