Hi, Do you still have this? I have just reassembled a 9500 from a pile of bits - previous owner took it apart to change the drive cords but couldn't put it back together! Unfortunately, now its back together I have found one of the plastic strips from the middle of the bottom glass panel is missing. I think yours still has them in place? If you do, then I'd be happy to have them off you.
Many Thanks
Steve
