Hey,
I have just bought a 3300 beocord and someone has removed the two 'data link' pins - does anyone know where I can source some replacement pins?
thanks,
Joe
Try contacting Martin (Dillen) via a PM on this site. I am sure he will have the two pins for you.
Ben
You only need one so, if you have another datalink device, you could pinch the non active one from there!!
Peter
