HI there,
I have a BV7 7 32' and I am still very happy with it as I use it with a projector.
The DVD aluminium protection fell. It seems not broken at all but I have no idea of how I can fix it back correctly, I do not see any screw neither any glue residue.
If anyone can hel it would be nice.
Mat
Mind did the same thing and I just glued it on and its been there ever since and works fine!
Not sure why they fall off........I couldn't get mine back on and I assumed a clip must have given way with use.
Thanks for your reply.
You have just used "superglue" ?
I used contact glue where you'd put glue on the back of the lid and where on the black plastic attached to the tv....wait a while and put them together.
