PUC IR Blaster interference with Wi-Fi
Marcello
Posts 213
Marcello Posted: Sat, Jun 20 2015 9:21 AM
This is just a heads-up.
After a reshuffling of my sources on the back of my BV11(Sky Box, Apple TV, Mac Mini, Airport Extreme,a PS4 and a 5-port ethernet hub), I was going crazy because I was not able to control my Sky Box with the BeoRemote One.
The box would respond to one button press out of ten in the best case scenario.
I changed the PUC cables, erased the local PUC database, downloaded tables, setup sources again. At some stage I reset everything to factory settings out of frustration. Ultimately I called the dealer and they had no clue as to what might cause the situation.
Turns out that I had put the Sky box and the Airport Extreme Base station in a single large bracket and the two devices were attached one behind the other. As soon as I put the base station on the floor, it started working again flawlessly!
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks for that info Yes - thumbs up
Page 1 of 1 (2 items) | RSS
