Beogram 3000 / Thorens - transportation screws where are they - if anyone?
Thanks Dave.
Just got it home - despite the cover, it looks like new. And for silly 35£ it's a scope, which will fullfit my 1967 Beolab 5000 system. Only need now is the Expander box.
It was a part of a more expensive collection of Beolab 5000 with weared print around the volume slider, a Beomaster in near mint, 2 pcs. Beovox 3000 with small holes / dints at one side each - i guess the have been used as brackets for a shelf between them for the 5000 - and a pair of Beocube 2500.
The 3000 still with B&O hanger sign at rear and all the papers glued describing the use with the Beocubes
Funny people know about the 5000 items and don't google the Beogram - maybe they allready did and only saw the later 3000.
My luck!
I allready have thes so I only bring home the Beogram .
Frede has the Beolab fronts made so the numbers cannot rub off now. Are you getting the 12" arm?
Peter
That sounds like a pretty incredible find!
Any pictures would be most welcome!
Ben
