Hello, I was thinking about buying a Beotime.
I know that Beotime can act as a remote for B&O products but couldn't find a list of what products it can control.
Can the Beotime control volume / skip / play&pause of Beoplay A9?
Thank you in advance!
BeoPlay A9 mark 1 has an ir sensor so can be controlled with Beo4 or anything that transmits the ir codes. Mark 1 is NOT multi - room compatible.
BeoPlay A9 mark 2 has no ir sensor so has to be controlled via Bluetooth remote or BeoRemote app and IS multi - room compatible (when the software update is released).
Opman
I have the mk1 A9 so it seems like I would be able to control some of the functions with Beotime.
Thank you so much for your answer Opman! You have been so helpful!
