Eclipse 65V1-32Beosound M5Essence MK2BLI
Excellent news - also need one/two for the kitchen and possibly bedroom.
Depending on the price of it - if it comes - the Essence and a BL7-1 would do the trick too.
Well that is a good point: depending on a price (if it ever comes). Essence + two 4000s (for example) might be a cheaper solution with better sound.
Only it would be convenient to have only "link" speaker, I mean less boxes, cables etc. :)
Do consider, that in the NL there is no 'link'-speaker/room, as we know it from ML.
Means: you can start playback in the kitchen/bedroom, and join in to that source (if join-able) in the livingroom afterwards - if that is what you prefer.
If you have (or want to buy) some WiSA-enabled speakers, you could stack a Transmitter1 on the Essence (and hide those) - makes it very easy to place the speakers, wherever you want.
Millemissen:If you have (or want to buy) some WiSA-enabled speakers, you could stack a Transmitter1 on the Essence (and hide those) - makes it very easy to place the speakers, wherever you want.MMThere is a tv - and there is a BV.
@StUrrock
1: common knowledge - at least I am sure, that AnalogPlanet know that.
2: you can always wait for better times ;-)
Would be nice with an Essence/WiSA, though.
Millemissen:@StUrrock 1: common knowledge - at least I am sure, that AnalogPlanet know that.
Maybe it is not a BL3500/NL, that is coming - but simply a new NL-enabled smaller speaker ;-))
Millemissen:Maybe it is not a BL3500/NL, that is coming - but simply a new NL-enabled smaller speaker ;-)) MM There is a tv - and there is a BV.
