Hope you can help.
My friends has the Beovision 4 65" the beosystem 3 has died (which is being sent off to be fixed). In the mean time can he transfer his non B&O amp (with sky and spekaers connected to the amp and just the picture going to the BV) into the tv room and use the BV running from the onkyo as a temporary fix (HDMI to DVI-d cable)?
Hope you guys can help.
Regards
Toby
Does anyone know if the BV4 can be just used as a monitor as a temporary fix?
Hope you can help before the England kick off tonight?
