I am trying to connect 2 BeoLab 3 + 1 BeoLab 11 to a Beo Sound essence but there is only 2 PL socket's for the speakers, how can I connect the 3rd speaker (the BL11)? Does anybody have an idea what would be the most convenient way?
Thanks for your quick response,
Luis Velutini
One cable goes from essence to beolab 11, then 2 from beolab 11 to each beolab 3
Reason is that the BL11 has Adaptive Bass Linearization or ABL. it will filter the bass signals from going to the BL3s to provide them some relieve.
Is one of the reasons I love my BL3/BL2 combination so much
Cheers
JK
Can I put, one cable from the BeoEssence to the Beo11-BeoLab3(Left) and the seconcable instead from the be11 put it from the BeoEssence?
BTW Thank you for your answer!!!! You made my day.
jk1002:Is one of the reasons I love my BL3/BL2 combination so much
I'm always scouring eBay for a good price on a pair of Lab 3s and Lab 2. I LOVED that combo. I may consider pulling the trigger on a decent offering, pairing the Lab 3 / 2 with my BV 11, and using the 9's solely for listening to music (stereo) in another room.
