Hi guis,
can you help me, I need to connect a pre-amp with chinch output to ML/MCL, but also need to swich it on and off.
I lost the diagram with the cables (with battery power) and wondering if any of you can send or post again it.
Thank you!
In this thread
http://www.hifi4all.dk/forum/forum_posts.asp?TID=23818&PN=1&TPN=1
You'll find all that you need.
But you probably will need some heavy 'google translating' ;-)
Thanks! This is what need!
