Hello, I have to change both the top of my serious speakers BeoLab 6000 . I received two new B & O but it is stated that we must adjust the level with a low frequency oscillator . Is this approach is mandatory and what is the risk if it is not realized ? Is this easy to do ?
Hey there,
I've done that to my Beolab 6000 some time ago. I did recalibrate the speakers as mentioned in the instructions.
To answer your question, no, you do not need to recalibrate the speaker. HOWEVER, this means your speaker will either underperform or overperform in bass, without the proper adjustment.
Calibrating is quite easy.
I don't have my notes in front of me, but you should be able to just do the following:
Things you will need
Process
Sorry it's not as detailed as I'd like, but I'm not at home right now. DM me if you have further questions, but I'm sure there's also plenty of members here who can help!
