beovox 1702
This post has 29 Replies | 1 Follower
Beovoxnewbie
Australia
Posts 25
Beovoxnewbie Posted: Wed, Sep 2 2015 4:17 AM
Hi everyone, l am a new member so l hope this is a question for the general forum. l purchased a pair of beovox 1702 speakers a few weeks ago and they sound great (l like the detail) however one woofers rubber surround has gone soft so l can only use at lower volumes to prevent over excursion. l have had an estimate locally here in australia to have the surround prof replaced but the estimate was excessive. Does anyone have a 2nd hand woofer for sale to suit, l think the part number is 8480098 or does anyone know what a suitable replacement would be? Any help would be greatly appreciated.
Søren Mexico
Mexico City
Posts 6,411
Velcome to the forum. changing surrounds is easy and cheap, search the site for surround or speaker repair
Dave Farr
France
Posts 2,283
The rubber surrounds are 6 EUR each. The glue is also cheap. As Soren says, to do this is relatively easy and is well described here on Beoworld. There are also a few tutorials on YouTube on speaker refoaming or surround replacement.
How much were you quoted? It is time consuming to do as you have to carefully remove the old surround, clean and then glue the new one in place. Labour costs aren't cheap. Some speakers you can do in situ which is easier and quicker but some drivers have to be removed from the cabinet to do this which takes more time and costs more.
There is a lot of pleasure from doing it yourself. I've done CX100, MS120 speakers and am just about to do some S45's and Pentas. Give it a try.
Dave.
Beovoxnewbie
Australia
Posts 25
thank you both for your replies, l will have a look around the site for what you have described.
Yes l think l will order a surround and give it a go myself as l am usually fairly handy with things, although have never done this before. l was quoted 150-200 to do one 5.25'' (13cm) woofer.
Are the rubber surrounds on ebay for 6 euros similar in thickness/structure to the originals as my other speaker woofer is still fine and l would like them to sound similar. Apologies for all the questions, just want to have all bases covered before l carry out repair, thank you.
Dave Farr
France
Posts 2,283
If one needs doing, the other will too in the not too distant future. Do both at the same time then you know they are the same and should sound the same - unless you also have a crossover issue and recap those too.
I'll send you a link of one of the better makes when I'm at my PC.
Dave
Beovoxnewbie
Australia
Posts 25
Thank you very much for your help. Ok, l will do both together. l have already re capped the crossovers,
regards.
Søren Mexico
Mexico City
Posts 6,411
If you count 2-3 hours for a speaker 150-200 USD are about right if you consider labor costs, I would do both drivers if one is bad the other one is on the way going bad. To clean off the old surround I use a small cutter blade. On the basket you can scrape hard and get it all off easily, on the cone you will have to be more careful, I place a finger under the cone at the scraping point and then scrape little by little until the glue is gone, do not cut or scrape into the cone, then clean off with mineral spirit or Isopropyl Alcohol again careful with the cone, just clean it with moist rag. Make sure you get the new surrounds with the correct dimensions
I use Aleene´s Tachy glue, did my first drivers some 5 years ago and they are still good.
Dave Farr
France
Posts 2,283
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Sep 2 2015 6:06 PM
Beovox 1702 does not use a 6-inch woofer!
I never saw any surround problems with Beovox 1702, what happened?
Dave Farr
France
Posts 2,283
Martin,
All info I see is for a 15cm or 150mm driver here on Beoworld or Beophile. That's nominally 6" give or take a mm or two.
Dave.
Dillen
Posts 13,191
Dillen replied on Wed, Sep 2 2015 7:46 PM
True, but unfortunately, there are several typos and other "issues" in our product guide.
The Beovox 1702 uses a 5-inch woofer.
Surround 125mm outer diameter (or thereabout). Just measured,
Dave Farr
France
Posts 2,283
Dillen:
That's interesting as Beophile etc have the same information.  I think I have a pair somewhere but haven't checked them.  In that case, it may be worth dropping GoodHiFi a message about it (the OP not you Martin).
Dave.
Dillen
Posts 13,191
Dillen replied on Wed, Sep 2 2015 9:06 PM
That's probably because the information was merely copied from the catalogues, where the woofer
is also listed as 6-inch.
Unfortunately, even four wrongs doesn't make one single right.
The woofer is a 5-inch. I just measured it tonight on the pair I have in my repairshop.
Dave Farr
France
Posts 2,283
Martin,
I never doubt you. Goodhifi need to make some changes.
Dave.
Dillen
Posts 13,191
Dillen replied on Wed, Sep 2 2015 9:29 PM
So do we.
Unfortunately, managing the product guide is not within my jurisdiction.
Dave Farr
France
Posts 2,283
Dave Farr replied on Wed, Sep 2 2015 10:11 PM
Unless an expert or very experienced and knowledgable person such as you points it out, we tend to believe what is written - especially once it's repeated elsewhere. One of the problems of the Internet.
Goodness only knows what else is inaccurate?
Dave.
Søren Mexico
Mexico City
Posts 6,411
Dave Farr:
So Beovoxnewbie will have to explain to us, whats wrong with the surround (pic?) and then pull out his vernier and take measurements.
Beovoxnewbie
Australia
Posts 25
Thank you to all of you for your replies/help. You are correct the speakers are 130mm (5'') to the edge of the basket frame lip, 119mm to outer edge of rubber surround, 114mm to outer roll, 90mm to inner roll and 85mm to inner edge of rubber surround where it meets cone.
I will have to try and post a pic later but the roll part of the rubber is somewhat flat and has lost tension, almost like someone had sat it face down on something in the past. There are some radial markings also. Not sure how this could have happened though as when l bought the speakers recently l removed the grilles to check things out and l can only assume (these being my first beovox's) that they had never been touched as factory adhesive seemed to be intact around circumference (quite hard to remove grilles). Both surrounds, woofers, tweeters and crossovers (before recap) all look to be factory original.
Dave Farr
France
Posts 2,283
You can still buy from Goodhifi but tell them the dimensions of the surrounds you need. They will have some that are suitable. They can amend their website then too.
Dave.
Beovoxnewbie
Australia
Posts 25
Thanks Dave for all your help, l will do.
Dave Farr
France
Posts 2,283
You can search their website for foams/rubber surrounds for 5" speakers.  The range is a selection covering most sizes that are nominally 5".
Dave.
Beovoxnewbie
Australia
Posts 25
Thank you, l will have look to find best match on their site.
Here is a pic of worn surround, l know it is prob hard to see but compared to other surround on good speaker this one is NOT nice and rounded or plump looking.
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Sep 4 2015 8:06 AM
Unless the sound is affected, I suggest you leave it as is.
//Bo.
A long list...
Beovoxnewbie
Australia
Posts 25
The sound is not greatly affected however l usually have to run amp slightly balanced to other speaker because the worn surround on this speaker makes it more sensitive. l also have been using them with the grilles off so l can keep an eye on the excursion of this woofer with worn surround, have noticed l cant turn the bass or volume up too much as the movement on this woofer becomes far greater than good woofer.
Nice sounding little speakers however not an ideal situation having to keep an eye on woofer travel all the time as not to cause any damage.
I have ordered some surrounds earlier today from good hifi (r57's)
Beovoxnewbie
Australia
Posts 25
Hi, just to update, l have fitted new surrounds to woofers, fitted new stainless screws and replaced speaker grille cloth. Speakers are sounding great. I had to remove original paper spacer ring from woofer outer frame to fit standard profile replacement surrounds.
The grille cloth l purchased locally (Aus) was a very close match for original, not exact but close, can give details of seller if anyone interested, they have just ran out of stock but are expecting more in next couple of months.
Thank you to you all for your help.
Dillen
Posts 13,191
Dillen replied on Mon, Dec 28 2015 8:21 AM
That's another pair saved. Nice work !
Beovoxnewbie
Australia
Posts 25
Thanks Martin for your reply, it is appreciated. I am still amazed at the sound of these little guys, hard to believe they are only 22wrms. As an aside what Beomaster would make a good period correct companion for these, maybe a 901? l do like the look of this model.
Milton.
Dillen
Posts 13,191
Dillen replied on Mon, Dec 28 2015 5:27 PM
Yes, they are surprisingly well sounding speakers. I use a pair in my repairshop.
Beomaster 901 (or 1100) would be a good match, yes.
Alternatively, a Beocenter 1400 or 1500 (or 1600) if you'd like to have the casettedeck too.
Beovoxnewbie
Australia
Posts 25
Thanks Martin, l will have a look into these other models you recommend also.
Milton.
Beovoxnewbie
Australia
Posts 25
Hi guys, just a quick question, the little 1702's are still sounding great and l have used them for many hours over the last couple of weeks since fitting the new surrounds.
However the glue l used from good hifi doesn't seem to have cured completely esp on the inner surround to cone area, it has stayed very tacky, have any of you experienced this?
Milton
Page 1 of 1 (30 items) | RSS
