Beocord 7000 drawer getting stuck...
MrRoast
Posts 340
MrRoast Posted: Thu, Aug 6 2015 7:40 AM
Hello all,
I've just acquired my first Beocord 7000 and could do with some help!
When it arrived the top cover wasn't on properly so I tried to re fit it. However, when it's on it appears to be impeding the cassette drawer. Without the cover is opens and closes perfectly.
Here's a pic of the inside of the cover. On one side it looks like the little metal tabs are angled out more. To me it looks wrong [:\'(]
And the other side
Once I get this sorted its onto why the play head is stuck out!
Die_Bogener
Posts 192
Definitly damaged and bent...
MrRoast
Posts 340
MrRoast replied on Thu, Aug 6 2015 5:34 PM
@Die_Bogener
Once again thank you! Yes - thumbs up I didn't think it looked right but wanted to check before attempting to bend them back.
MrRoast
Posts 340
MrRoast replied on Fri, Aug 7 2015 10:34 AM
Success! I gently bent the tabs back and everything now fits and works smoothly. However, it looks like it's had something heavy on it as the top is slightly bowed but not so much that it impedes the cassette drawer.
Page 1 of 1 (4 items) | RSS
