Hi..
I have been offered a cheap, well looked after, set of BL4000, but one of them is suffering from the "no green light, but red light" problem..
In the service bulletin, this is mentioned...
Short-circuited primary windings on 1T1stand-by transformer p/n 8013582Symptom: No light in the stand-by diode and no switch on from stand-byCause: Short-circuited primary windings on 1T1 stand-by transformer due to peaks on the mains.Solution: Replace 1T1 part no.: 8013582.From serial no.: 13750371 an isolating foil has been introduced between the primary windings which will solve this symptom.
Anybody know if this trafo is available as a spare part still ? I have not een the serial number yet, so it could still be the tweeter issue, but that should still be available I guess ?
/Weebyx
