Can anyone advise me if it would be possible to connect a Beocenter 2 from its digital output to the SP/DiF-in connection on the BV11 and then connect a Beogram 3500 record player [the version with Preamp built in] to the AV-in connection on the Bv11 i.e. the connection beside the SPDiF?I don't need the video function from the BC2 as i already have a bluray player connected to the BV11-I only need the audio [CD and Radio] functions. It would simplify my set up if they was a workable and working solution.Many thanks for any help.
http://archivedforum2.beoworld.org/forums/t/16382.aspx
Thanks MM .I have been following that thread with great interest! Still not sure if one can attach both sources to the 2 connections and achieve my hoped for result..am I correct in thinking you may have the same doubts? If it proves impossible is the solution then to put the Beogram through the BC2 and from there to the BV11 via digital out ? or must I use another route? I must admit to being pretty much a novice with this sort of thing so all help and advice is most welcome.
