mains power switch 240v via Powerlink signal..how to ?
marexy
Posts 710
marexy Posted: Wed, Aug 5 2015 7:24 AM
Hi
I would like to do a mails switch for 240v which would turn on with the Powerlink signal from the B & O speakers signal.
How this could be done?
I ask for suggestions and drawings.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Aug 5 2015 8:37 AM
Maybe look for one of these on eBay - I changed the plug on mine to connect straight to a Powerlink socket.
http://www.beoworld.org/prod_details.asp?pid=1246
There are some on eBay right now.  (EDIT: They are 110v US versions (4001). You need the type 4002, 240v)
There's also some info here: https://www.beoworld.org/beotech/circuit.htm
if you want to make your own.
marexy
Posts 710
marexy replied on Wed, Aug 5 2015 11:43 AM
Yes ..that is what i need.
Regards
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Aug 19 2015 7:16 PM
There's one here if you are still searching! http://www.ebay.co.uk/itm/Bang-Olufsen-Remote-Mains-Switch-4002-/221848677456?hash=item33a7362c50
(Not my listing, by the way!)
Page 1 of 1 (4 items) | RSS
