I recently obtained a tx2 that is not working properly. The problem is that when I press play the tone arm moves to the beginning of the disc, the the tone arm does not drop, it just runs across the disc and the returns and shuts off. Could this be a lamp sensor problem, I do not see any light coming from the bottom of the sensor arm, should there be any?
Thanks, john
Cartridge mounted?Tracking force set correctly ?
