hi i have bought a beogram 2200 deck and the din plug has been cut off. could anyone help me with the re wiring arrangement of the cables. there is a black cable with its common ground, a white cable with common ground both sheathed with a earth winding binding the two together. hope someone can help me am new to the b&o world but hooked already. many thanks in the anticipation of a reply. dean
I have few DIN plugs,. One has two male pins, one has two female pins, one with two stereo pins. Which one are you after?
B&O used the standard DIN wiring configuration for the DIN connectors
with a five pin plug the pins are numbered 1 4 2 5 3
3 being the common ground
5 & 3 being signal output. 3 left. 5 right
ERROR
in my previous message I mistakenly wrote that pin 3 was the ground ; that sound have been pin 2 (in the middle of the semi-circle)
apologies
p.s. White might be Right ( rhyming )
