Hello!
I've got a Beolab 3500; now after installing it the display kept dead - no red dot or anything that would give a sign of life.
The manual says that there are 2 buttons - mute and timer -> but there seems to be no reaction...
I do not think that there is a pin protection?!
Any ideas despite contacting my dealer?
Thanks, Elmar
Hi Elmar,
how is your BL3500 linked up?
More details, please?
Hello MM!
Thanks for your quick answer!The BL3500; Type 1601, Item 1160112; Serie 20xx was unplugged over some days; before it was said that it worked
I plugged in ML (cable) and Mains without any reaction of the BL3500 - I expected that somewhere a red light will get on but the display was dead
in the manual it says there are 2 buttons as well - but trying to use/push them (timer/mute) was not very successful
so: is there a fuse, something small to check?
will there be a the red light without ML?
Elmar
