I've made 5 replies to posts over the last 2 days and they just disappear into the ether! No reply is posted on a thread so where do they go? It's very frustrating as normally I have no problems using my iPad for posting.
Dave.
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
iOS 8.4.1 safari and os x 8.0.8 can not edit post on beoworld. You have to open chrome for this. Also sending post is slow so you many times find yourself pressing post a second time and - double post is your game.
Beoworld pull- down menus don't work with Safari on the iPad, nor do smileys, and links are impossible other than posting web addresses in full. Otherwise, iPad still manages to post (if this post appears!)
Graham
Martin: iOS 8.4.1 safari and os x 8.0.8 can not edit post on beoworld. You have to open chrome for this. Also sending post is slow so you many times find yourself pressing post a second time and - double post is your game.
Safari for Mac has the same issue, can't open the menu on a post to edit it.
Dave Farr:I can normally post and edit via my iPad but recently when I hit the 'post' button, nothing happens and my reply is simply lost and I have to redo it or use my PC. Otherwise it normally works fine. It's only been over the last few days. No problems with speed when it does work or with duplicate posts. Dave.
Martin:iOS 8.4.1 safari and os x 8.0.8 can not edit post on beoworld. You have to open chrome for this. Also sending post is slow so you many times find yourself pressing post a second time and - double post is your game.
BeoNut since '75
Same app that I use.
Dave Farr: For a free app, I'm grateful that it is available and continue to use it. Dave.
