I'm having a strange issue with my Beovision 6. I had been using it in my living room connected to a sky box and STB controller but have now moved it to a bedroom where i would like to use the built in DVB-T tuner.
The issue i have is that the Beovision will not receive any of the BBC channels, only ITV and others. My other Samsung TV's are receiving all of the channels so i know its not the aerial at fault.
I have tried retuning but with no success.
The TV has previously been able to receive the BBC frequencies - i wondered if it was possible that the BBC have swapped frequencies to something outwith the capability of the Beovision?
DVB-T software version is 0.2.0.0 dated Nov 27 2008
has anyone else had similar issues?
Beocenter 8500 / Beolab 4000 / Beosystem 5500 / Beolab 8000 / Beogram 2000 / Beosound 8 / Beovision 6-26 / Beovision MX4000 / Beomaster 1900-1 / Beovox CX50 / Beoplay H4 / Beoplay A1 / Beocom 1401 x2
I had a problem in the past when on retuning the TV picked-up weak BBC stations from another region before the more local broadcasts were reached in the tuning sequence. For some reason my TV locked onto the weaker stations.... hence no sound or picture.
We had another problem on a later retuning where the new digital output from the North Wales transmitter was so strong it was picked up in preference to Winter Hill (NW England). That particular problem was dealt with by leaving the aerial connection out until the tuning band had already moved about halfway across the progress screen.
My 6-23 has an external Freeview tuner and after the last retuning it put all the BBC stations out of order and they could only be found after all the radio and 'Adult' channels. That turned out to be a failure to select the option for the tuner to put the stations into a logical sequence (apparently determined by the broadcasters and transmitted as some sort of code). Another possibility is that you need to do some sort of factory tuning reset (rather than just retuning) to make sure that the TV tuner forgets all the old stations in case the BBC have in fact changed frequencies.
These TV tuners do do strange things from time to time. Freeview Sky News is often missing after I do a retuning but returns after two or three attempts.
Graham
When the analogue broadcasts were switched off B&O had to introduce a "workaround" to some of the new Freeview channels. It's a while since I had to do this but from what I can remember you have to manually amend some of the settings in the tuner menu. If nobody else can help you I will refer to my notes next week when I return to work after my hols.
This applied to the older DVBt tuner, the later DVB-HD tuner wasn't affected.
Hope somebody else can fill in the gaps in my memory. If you don't have a solution by next Tuesday, please re-post and I will investigate.
Opman
Hi Opman, i'm afraid I am still struggling with this problem.
Do you have any further information on how to access the tuner menu settings?
thanks so much for your help!
Hi Scott
I have found my old notes relating to this issue when the analogue broadcasts were switched off in the UK. At the time it was a known issue that after retuning when the digital switchover happened, some B&O sets were unable to tune into BBC.
The technical jargon (wasted on me) is that the UK introduced a 166Khz offset from the standard ccir channel raster. Offset channels channels are named Ch.xx+ and Ch.xx-, depending on their offset direction.
DVBt modules with older software may not find the offset frequencies at all.
The first thing to verify is that your TV/DVBt module has the most up to date software.
Opman, i've just followed your instructions and great news my TV is now fully functional with all channels!
Thanks so much for your help with this!
I am absolutely delighted!!
Dave Farr:Great news. Well done that Opman. Dave.
Dave.
+1 👍
Scott: Opman, i've just followed your instructions and great news my TV is now fully functional with all channels! Thanks so much for your help with this! I am absolutely delighted!!
Glad to be able to help
Regards
