V1 PUC code for Cisco 4742HDC Set top
fasonista
Posts 2
fasonista Posted: Sun, Sep 6 2015 1:04 AM
Any V1 users? I am new to the forums. I live in Brooklyn, NY, and have been trying tirelessly to find the right PUC code for my Time Warner Cisco set top box. Its the 4742HDC and although I have connected the IR blaster to the correct spot where the IR eye is, and have selected every Cisco PUC code listed (only 9 of them), I still have not been able to control the device w/ my B&O remote. Even the 'generic' US cable box (cisco) PUC didnt work. Anyone have ideas? Thanks, Jason.
BeoLinkapp
Posts 10
Try all of the U.S. Generic cable box codes, one of them should operate your box, it may use a different codeset even though it states Cisco on the outside, try the sci Atlanta codes first for Time Warner
BeoLinkapp
Posts 10
fasonista
Posts 2
BeoLinkapp Awesome, that totally worked! It was the Sci.American setting. First try. Many thanks! Jason.
Page 1 of 1 (4 items) | RSS
