beomaster 8000
This post has 15 Replies | 0 Followers
lotus73jps
Posts 141
lotus73jps Posted: Sat, Sep 5 2015 11:31 AM
hi can I add a subwoofer to my beomaster 8000 ? if so were would you connect the subwoofer to the 8000 thanks
j0hnbarker
Posts 187
Presumably to the Speaker 2 output?
For a laugh I added a spare Cona this way that was switchable in and out with my Pentas if I wanted more boom.
lotus73jps
Posts 141
hi speaker 1 and 2 are both in use with 2 pairs off beovox 500 ? is there any other way ? it can be done thanks
Dave Farr
France
Posts 2,283
Just use a Cona (or 2).  It's placed inline before your Beovox 5000's.
Dave.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Sep 5 2015 4:16 PM
I am trying - horrors of horrors - a pair of Ditton 66s at the moment. Who needs a subwoofer anyway? Big Smile
Trouble is, such a device always lives its own life and for me it does nothing for the music.
That said, the B&O circuit is very sturdy and you should be able to drive a Cona without any problems. But don't expect subsonics here!
Jacques
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Sep 7 2015 8:23 AM
Use the MS150s designed for the system and you don't need a sub woofer!
Peter
Cooker
Posts 116
Cooker replied on Tue, Oct 13 2015 12:18 AM
Hi, can you explain exactly how to place it inline before the speakers?
Whats the exact routing from the amp? Wouldn't you have to have both speaker inputs going to the subwoofer (left and right)?
Sorry, If this question comes across as a bit dumb.
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Oct 13 2015 7:22 AM
lotus73jps:
"Beomaster 8000" "beovox 500"
Odd combination
//Bo.
A long list...
Cooker
Posts 116
Cooker replied on Tue, Oct 13 2015 3:32 PM
I have just done some research into the Cona and I now understand how to connect it.
An odd ball question, I have 1 set of M75's connected to my Beomaster 8000. They are great, but really lack low down Bass. I would love a set of MS150's to replace them, but being in Western Australia, they are as rare as hens teeth. Until I finally get my hands on a pair, how would connecting 2 Conas go. Would I notice much difference with them complementing my M75's? Better to use 2 other passive non B&O sub woofers instead of the Cona, as the Conas arnt really massive powerful subs and wouldn't really help M75's?
Søren Mexico
Mexico City
Posts 6,411
The M75s goes down to 27 Hz, the Cona to 40 Hz, so the Cona will wont help much. Did you check the crossovers on the M75s, I have a pair of M70s and no problems with bass what so ever.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Tue, Oct 13 2015 4:09 PM
Søren Mexico:
The S75s goes down to 36 Hz, the Cona to 40 Hz, so the Cona will not help much. Did you check the crossovers on the S70s
I am with Søren. The M75's really should produce good bass for you. Something isn't right if they aren't. Have you checked that the Filter switch is operating correctly on your Beomaster 8000 ?
I have the Cona subwoofer paired with a pair of CX-100 speakers. It does a nice job and looks really good but my experience has been that the Cona doesn't really pump out the bass if that is what you are after. The best bass I have got from vintage B&O speakers are from the M100 speakers. In one of my rooms I have the M100's paired with some MS150's. Those do provide a very loud experience ... and the bass is good of course.  Another option to try is a dbx 120x-DS Subharmonic synthesizer. It could go between the Beomaster 8000 filter out and in plugs. The dbx allows you to dial in as much bass oomph as you like.
sonavor
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Oct 13 2015 4:55 PM
Are you sure the woofer is operating correctly on the 75's?  Sounds odd to have little bass.
Dave.
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Oct 13 2015 5:02 PM
I have older M70 speakers which are roughly the same cabinet size and have the same woofer and they do produce fantastic bass. Placement is everything, however.
Jacques
Cooker
Posts 116
Cooker replied on Tue, Oct 13 2015 11:25 PM
Yes, they are all working correctly, no problems with them. I just notice they they Bass they produce isn't as deep as I would want. B&O did make the M100's for a reason after all in the M lineup in the late 70's.
BO
Halmstad, Sweden
Posts 728
BO replied on Wed, Oct 14 2015 9:58 AM
Cooker:
The M75 and M100 share the same low frequency specs. I have the M100 and M70 and the both produce very low and precise bass (if stronger bass is needed, use the tone controls).
//Bo.
A long list...
Cooker
Posts 116
Cooker replied on Wed, Oct 14 2015 12:37 PM
No, I hate adjusting the tone controls for more bass, as it just makes everything more bass, even vocals. What I want is just the bass to be more sharper bass if that makes sense.
Surely the M100 or MS150 would address this? I found this from the website about M100 in comparison to the M75 "Special emphasis was placed on Beovox M100's ability to reproduce clean, powerful bass. That it why it was given a ported bass-reflex cabinet with a 30,5cm woofer"
So surely the M100 is an improvement over the M75 as far as base is concerned, otherwise why state this??
Isnt that what the M100 is over an M75? More power and better bass? Just because it does the same frequency range, doesn't mean anything as far as quality of those frequencies is concerned.
If the cona wont help me, I guess I have to continue my search for a pair of M100's or MS150's to replace my M75's. Or in the mean time, a decent pair of standalone subwoofers.
Page 1 of 1 (16 items) | RSS
