Normal 0 false false false EN-GB X-NONE X-NONE
I’ve been using my beomaster 5/beosound 5 happily for more than a year now. I would like to use it with creation 5 on an iphone, needs to be set to audioserver = yes, but as the user manual specifies, once this setting is chosen, the beomaster doesn’t go in standby mode anymore. Is there away around this, to stay in this mode and still have the beomaster going in standby?
Thanks,
In the latest version of creation 5 (juste tested yesterday), beomaster 5 doesn't need to be enabled as an audioserver anymore. So problem solved, C5 working much better than before, and beomaster 5 going in standby mode as usual.
The only none working function in C5 is youtube. Have now access to many more radio stations, my CD librairie.
Cheers
