Hi, I have a beosound 9000 with a pair of 8000s attached to it, that I'm trying to move into my living room to use with my TV, (Sharp TV, feeding off a Tivo and Apple TV). However I was hoping to use the beo4 remote to control everything. I know the beo4 has its own frequency that doesn't work with other equipment, but I was wondering if there was some sort of converter, or possibly another type of universal remote that would streamline things. I'm setting this system up for my mother, so I would like to make it as easy as possible for her. Thank you
Lintronic is the gold standard for using the Beo4 with non B&O devices. If you have a PC, it is pretty easy to work with and program the converter box.
