Hi to all,
unfortunately I've replace the belts in my tape deck in Beocenter 9500 and no significant improvement - doesn't work or work as it used to work. When I push the play button the head goes down but the tape is not progressing. Any idea what could happen, what is the reason? The rewinding works one side and other sometimes but I can hear some "wrrrrr" and no action.
I'm thinking about getting another tape deck mechanism but there is issue where to get it. Do you know someone who has it on stock? This is 3 belt mechanism - so the new type.
Thank you for your help in advance!
Max
